Blue Chinese Machine, Ruida controller.
I set up Lightburn. It took a while to recognize my machine. I ran a few files. I realize I have my set up backwards as it outputs as a mirrored image. But the laser is now not connected with lightburn. on the laser panel it says LAN off. is that the issue and where on the machine can I change it? I got this laser second hand and have no manuals or original settings
I am trying to use the USB. I hadn’t thought of Bluetooth
I had thought I’d sent this. I have turned off bluetooth and no result.
I have located the LAN port and plugged a cable in but LB wants to know the IP address which I did not have.
