Machine Settings Button
Hi,
It would be very helpful, especially during setup process, if the “machine settings” were also reachable by a standard button, instead of “Edit -> machine setting” from the menu bar.
It’s annoying to do this for every little adjustment during Laser setup process.
Also the eeprom settings should be expanded immediately and not need a further mouseclick.
Next update?
Machine settings is something that few people need to access constantly, so having them take up space on the main display seems wasteful. (I’m likely going to remove the main settings and device settings for the same reason).
And having the motor settings section rolled up is necessary because people are less likely to click things randomly in there if they don’t see them right away.
All settings available in this menu are also changeable easily from the console, so if you need to make constant changes, that’s the simpler way to do it.
