HI
I am using an Xtool S1 40W laser and when cutting test material sheets(engraving in this case) the outline shows fine on the preview as a square, but is cutting or engraving as a triangle(I tried 100% power to cut it out first) and it cut diagonally across the test area
XTool jank in full effect:
Thanks, i installed that version and tested. Same problem occurred with the square being cut as a triangle, but other components OK
Someone who knows what should happen and can make use of what you just reported: paging @Colin.
