I would like to use the new Material Test Generator tool, but I have diode laser. I tried to enter 100mm/min as minimum, what is 1.667mm/sec, but if I enter lower value than 60 mm/sec the software corrects it to the last value what greater or equal to 60.
The units are not visible, but according to this forum thread we need to enter in mm/sec the speed values.
Thanks
I believe I saw a note that indicated that speed settings should now reflect your setting preferences. So if you are set to mm/min this should show in the tool. I may have misunderstood, however, as I have not tested this.
Have you tested this to see whether or not you get the right speed?
Thanks for the reply. No, I don’t tested it, but it’s a really good idea.
I will do it.
