The material thickness seems not working.
When device setting is not on relative mode, the gcode it generated use relative position.
Following is part of save gcode:
G21
G90
G0 X121 Y312.79 F2000
G91 ← set to relative position
; Scan @ 799.998 mm/min, 25% power
M106 P0 S255
M05
G0 X0 Y-26.8 F2000
G0 Z7 ← isn’t it should be absolute position?
The relative move mode is set. I didn’t see any Z move on the gcode.
I don’t believe that disabling “Relative Z moves only” implies that only G90 commands will be used. Similarly, if you use Absolute Coords for your coordinate system LightBurn will still use G91 for jobs depending on circumstances.
Did the end position for the Z height still end up where expected? Or are you posting because material height is not working as you expect?
If so, can you describe the specific circumstances of what you’re seeing?
I’m not sure where to set the focus length.
This is how I setup.
Z0=focal length.
If I put material thickness of 7mm, it will advance to Z7 which is correct.
If I re-run the job since it is relative positiion, Z will be Z14. This is not what it should be.
It should be Z7 since material thickness still 7mm.
You can see that it’s using absolute moves and goes to 7mm Z appropriately. I would expect it to go back to starting position but maybe that makes sense. Not sure.
This was done with Absolute Coords. I noticed that if I use Current Position it uses relative moves but does go back to starting point.
