Hi I have a problem regarding the max travel of the axes. I have a co2 laser with a working area of 1900mm X 900mm. If the laser moves above 900mm it stops so I have to restart grbl and move again and if I do the homing it does not stop.
Max travel in grbl is correct. This happens with every software I use. Can someone help me?
Read the how to ask for help.
Post all the details including screenshots.
You’ll get help much much quicker if you do this.
my machine is a 80w co2 laser that I modified using a mks dlc32 with DM542 stepper drivers that work at 24V. As I already wrote with any software I get the same problem. It is not a problem of Grbl settings.
Which means it is a machine setting issue. In the console window type $$ then press enter. Copy and paste the output here for examination.
