In the machine settings on a Ruida controller, there is a place to record min and max laser power.
If I list a minimum 11% and max 65% here - What happens when I set a cut or scan power setting? Can I list 5% power it’s 5% of the 11-65% range (13.7%)? Or 50% in cut settings would become 38% at the laser (50% between 11 & 65)
Alternatively I thought that perhaps I’d recieve an error message, but did not. I don’t have a power meter to confirm actual numbers and am worried most about the upper end of the settings and blowing the tube prematurely.
However, I read through the post and didn’t see what the actual use of the min & max power in the machine settings was though…
[Edit] Oh - I re-ready and it seems to indicate that if I set power to anything more than 65%, it’ll just fire at 65%. And if I set at 5%, it’ll change that to 11%. Correct?
Correct - I’d want to test with a really low max power (20%?) on the machine setting to confirm that if the LB cut setting is 100% the actual power is limited to 20% power as expected.
