risitanyc
(Yanira Rodriguez)
February 17, 2023, 4:00am
1
I have looked in as many places as I can but I can’t seem to figure out how to get the option in the cuts/layers window to enter the material thickness for each layer. I enabled “Enable Z Axis” and also enabled “Optimize Z moves” but the box still doesn’t appear like I see in other posts.
This post contains exactly what I’m referring to.
Dear Ken,
I had the same issue on my Gweike Cloud machine. I found that setting while watching the “Gweike Cloud and Lightburn” YouTube video.
Go to Machine Settings and enable z-axis:
[settings]
After that you will see a new field “material thickness” in your "cuts / layers - window"
[material thickness]
Here you will have to enter “material thickness + 11mm”. For example I often use 3mm basswood, then the setting is 14mm.
I was not able to find out where to enter the constant of 11mm y…
berainlb
(PY)
February 17, 2023, 4:03am
2
Do you also have “Relative Z Moves only” enabled? If so, Material Thickness will not appear. Disable that and the field should appear.
risitanyc
(Yanira Rodriguez)
February 17, 2023, 4:15am
3
I knew this community was going to be good, but jeez! Thank you so much. That did the trick!
Thank you both!
I’ve added this to my post about setting up the cloud now too.
I think I worked this out so that it moves down at the start of the cut, and moves straight up to the home position at the end. I haven’t had a crash yet doing this. (I’m still new to my Gweike cloud, so I’ll update this if I get more info).
To set up the Gweike Cloud Pro with LightBurn;
Plug in usb cable from laser controller to computer. (note: there are two ports, one for the camera and one for the laser controller)
Install drivers from Gweike website as per this video: How to use Lightbur…
system
(system)
Closed
March 19, 2023, 4:17am
5
