I have a MKS DLC v2.0 board. When trying to connect it with the PC it comes up with an error saying windows cannot find a driver and the device has malfunctioned.
I have tried uninstalling the driver and re installed it. Didnt work. Ive also got a Nano board that connects perfectly.
Ive tried switching out the USB etc as well as using a different PC.
Youāll need the CH340 drivers installed to talk to this board.
I donāt think Lightburn includes these drivers, but it might. One way you can install these is from the āToolsā menu of LaserGRBL if you have that installed.
Another thought, I have several GRBL boards around that are based on the arduino. All of those boards will talk to the computer using just USB power.
This one will not, and it takes 20-30 seconds for mine to respond to an $$. I know itās basic, but you do have power to the board, right? Just trying to cover all the bases.
anyway also this is not normal, i have 3 of those boards on 3 different engravers and all 3 responds immediatly when connected with USB. If your do not act like this maybe there is some issue elsewere
if you get a ādevice unknownā in windows device manager you need to install drivers, you can install LaserGRBL and in ātoolsā you can find āinstall CH340 Driverā click on there and install
If you bought the board online can you post a link to where you bought that one from? Iād like to know more about it and which firmware might be flashed into its memory.
So⦠i got another board from the supplier this time its a V2.1. I plugged it in and bellissimo it connected right away.
However LB console has āwaiting for connectionā and it wouldnt connect to LB. After trying multiple times i managed to flash the firmware through xloader and now ive got everything to work.
Im yet to try a firmware update on the first board but i doubt its going to work and putting it down to a faulty board.
Seeing as Iām invested Iām going go try an air assist with a solenoid. I have no idea how this is going to work but Im sure google will have something.
