ich verwende die neuste Version LB 1.6.03 mit meinem 30W MOPA M7 Faser Laser und erstelle gerade mit mehreren “Material Test” einige Tests auf Edelstahl platten, damit sehe wie das Material reagiert und welche Farben entstehen.
Nachdem ich mich für eine Einstellung entschieden habe, habe ich diese Einstellung für eine Ebene verwendet, jedoch scheint es mir, als ob die Software die Eingabe in dem Feld “Q-Pulse” ignoriert und den höchsten Wert (vermutlich 200ns) verwendet, anstatt meinen eingestellten 8ns.
Ist das ein Fehler in der Software oder habe ich eine Einstellung übersehen?
Hello I’m using the latest version LB 1.6.03 with my 30W MOPA M7 fiber laser and I’m currently doing some tests on stainless steel plates with several “Material Test” to see how the material reacts and what colors are created.
After deciding on a setting, I used that setting for a layer, however, it seems to me that the software ignores the input in the “Q-Pulse” field and uses the highest value (presumably 200ns) instead of my set 8ns.
Is this a bug in the software or have I missed a setting?
Hello, Gummi2000 Guessing you are trying for reds with the 8ns? And with material test you get the correct results but when you duplicate those settings in the cut/ layers settings you get different results? Or different results only with other program?
Please post as many screenshots as you can, your cut/ layer settings, machine settings, Material test settings, etc.
I see what you are saying, speed 700mm/s 125 KHz, 8ns q-pulse 80% power line increment 0.0010 produces a light color (Green?) on the material test but solid black on the gator.
Do you have more then 1 cut layer in the file, and is it possible the gator is on the wrong cut layer?
If you want to post the file, I have some of those tags around I could try on my machine later.
When I download the file the frequencies are 20 KHz on the fill and 40KHz on the line, your material test is 125 KHz I won’t have a chance to run the file tonight but something to check.
Good luck!
Hello, Gummi2000
Does your cut setting editor show 125K or 20K?
I have not generated the screen you show above so you are way ahead of me on that, what procedure do you use to output the text?
Strange behavior.
I made sure my settings were 4000KHz max, re-opened your file, still opens at 20KHz. Created a new laser, same results. Shows image at 100KHz.
Maybe try deleting both the image and the line layer, and just sub layer layer 17 so one is fill, one is line. Just run the fill layer to start with.
