More detail/perfection
How can I get more detail/perfection in this engrave (MDF 3mm - Power 16/Speed 130 - DW6090 100W)?
Thanks for your help!
Increase the DPI setting and reduce the power to compensate for the extra burn. For example, if you’re using the default 0.1mm interval (254 DPI), you could change to 0.07mm, and drop the power to about 12.
Thanks for your tip, now I have a better result!
One more thing… when I have more than one object to cut or engrave, where I define to cut/engrave one by one and not all at the same time?
There are several options depending on how your file is structured. Have a look at this.
The most general purpose would be “Scan by Groups”. It’s in the video Rick shows above, and would let you group your objects for scanning however you like.
Thanks! :slight_smile:
