As you can see the working area (NEJEMax4E80) is correct 460x750, the square I made is almost in the center, 305.222, from left down corner. Now the laser is in the left upper corner, “Position” shows: 0.460, thats OK. Now I hit the button RIGHT, and the machine sounds horrible: can’t moving! Then hit the LEFT (which is nonsense in this situation) and the laser goes to the right! And the “Position” X is goes down, under zero, zero, zero.
Of course It cannot be framing, nothing to work.
Thanks for helping me!
If I understand correctly it can be fixed in one of two ways.
In red, go to the machine settings and invert parameter $3.
In orange goes to the “console” window to check what the value of $3 is and invert it. (in the example you would have to change it to 0. To do this just type $3=0 (if $3=1) or $3=1 (if $3=0) and press enter.
A genius is here! Thanks for the help, works the machine! The is truth that Im pro in woodworking - except with computer aided machines and in these days I try to learn it, but sometimes Im automaticly pressing buttons and Im so confused… I tried to operate with the rotary but it failed somewhere and then the all the settings changed for the “normal” working.
Thanks… and if later I will have problem… may I ask if You help me?
Welcome to the Lightburn forum! There are many members that provide help on the Forum. Nobody knows it all, but everybody knows something. Expect different members to offer solutions. And feel free to ask for help here.
We often use something like Google Translate to overcome any language barrier. If you do not know what something means, ask for an explanation.
Not at all. I was just the first to respond, any other forum user with a minimum of knowledge would tell you the same thing.
Besides, soon they’ll start asking me for three wishes and I have no way of granting them. ![]()
Regarding help, @MikeyH has already answered you. We are all here to help each other.
Believe me, this is a great community!
