Universal 5k blue machine.
I am trying to engrave text in a box. It is engraving all the movement lines in the preview as well as text. The minimum power setting is at 20 but I cannot change it. In line mode it appears to not be adjustable.
Show an image and your parameters, it make it somewhat easier to troubleshoot.
Thanks found enough info to fix. Now working as it should
Would you be good enough to go into the answer section and in there, maybe under the dots, is a SOLVED icon.
Please activate it so others can fina information which led to a resolution more easily.
Thanks and it’s great news you are in operation again
Regards
Gary
