My laser is not in line with x an y
When I run a project it is off from my laser position. I check where laser will run before so project is in line, but when I burn it is at an angle. How do I straighten this out and get my laser target in line with my laser? The plus or target seems to be off set to the left? Any help ? Not sure if there are settings for this or where to read or find it.
Did you import a configuration file provided by xTool when you first set up your device profile in LightBurn? If so, you will have a ‘Laser pointer offset’ in your Device Settings (‘Edit’ > ‘Device Settings’) to compensate for the difference in distance between the crosshair pointer on your laser, and the location where your beam will actually fire. That could account for the discrepancy you’re seeing.
You can try turning that offset off and using the ‘Fire’ button to frame instead.
