Need help in setting up xtool rotary to creatlity falcon 10w
I cant find detailed instructions on how to connect the cords to the laser to the rotary
The Yaxis cable to the stepper motor is unplugged and it connects to the rotary motor. There should be adaptor cords included with the xTool rotary.
Those and a manual were included with my xTool RA2 rotary.
You can also search the Forum for information. Here is a little bit to get you started. Use the Forum, it is a goldmine of information.
Thanks for the comments…when connected the rotary tool makes this horrible noise…the action is smooth operating when un plugged but when connected to the laser it acts up making this noise and not rotating.
I haven’t found a solute this on any video
I had this same situation with my rotary the first time I connected it. Not an Xtool, but similar. There should be a couple different adapter cables included with the rotary. Try them until you find the one that will solve the issue.
do you have any connecting cables to add? The second cable on top of the first brings the good wiring if needed.
It is hard to see in the image, but one of those pigtails has the middle wires crossed over.
All, I tried the mixture of different connectors and got it to work!
Thanks much for the input!
