Needed: AtomStack A5 GRBL Settings
I recently had to reinstall GRBL to my AtomStack A5. I inadvertently overwrote the device while programming an Arduino board when I picked the wrong com port. :anguished:
The controller is working again but the default GRBL settings are wrong.
Would anyone here with an A5 unit be able to post a copy of the default settings of their machine?
Just type $$ in the console window and copy the returned output.
Thank you for any help you can provide.
If you do a search on the forum you should find a number of posts that already include GRBL settings for that machine. Take a look.
Thanks for that berainlb. I found what I was looking for in the post linked below.
It seems to be working fine so far as movement is concerned. I’ll do an etching test once I get more time.
