NEJE 30 with SKR 1.4T
Hello, does anyone have this setup ?
Can you please tell me what pin you use control the TTL signal to laser ?
Because i think the mosfet logic is inverted.
So i found out PWM inverter circuit https://blog.eccentricworkshop.com/grbl-pwm-inverter-circuit/ and it seems to work ok.
Another type of solution could be to use photocoupler.
But i suggest to use faster type the PC817.
Or you can use some other PINs with PWM on motherboard :slight_smile:
