Hi!
I am trying to laser my project. If I push a button to set laser in to go to the spot on working area positioning seems to match perfecly. If I push burn project it goes into wrong spot usually like 10cm lower from working area and starts burning. If I reposition the work under laser again it goes lower and lower etc…
I tried press homing it but it didn’t help.
Neje Master 2S Max should have X are 810 and Y 480 so it seems I’ve set correcly. Homing laser didn’t help.
Waiting for connection…
Grbl 1.1f [’$’ for help]
ok
[VER:1.1f.20180715:����������������������������������������������������������������]
[OPT:VML,35,254]
Target buffer size found
ok
Homing
ok
Project loaded in 0 milliseconds
Starting stream
[MSG:Pgm End]
Stream completed in 0:06
Starting stream
[MSG:Pgm End]
Stream completed in 0:01
Starting stream
[MSG:Pgm End]
Stream completed in 0:02
<Idle|MPos:462.238,270.700,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
Starting stream
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Layer C00
Job halted
Stream completed in 0:15
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
ok
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
ok
ok
[OPT:VML,35,254]
ok
Homing
ok"
How to overcome this I can’t continue my project…
I should have no electric noise issue I’ve read on some forums it might be for a laser not to function properly.
