Hi, I try to use the Ortur Laser Master 3 Wifi with Lightburn, after several Cut the Laser does not get more data and stop. is there a patch to work with the Ortur Laser Master 3 Wifi ?
This seems relatively common that a wifi will not maintain a continuous connection and your data stream will fail. This is exacerbated with ‘grayscale’ or other operations that turn change laser power as the data stream is very large.
I don’t know of anything in particular about the ortur machine that can help this. Hang in there and see if someone has one of these with a better suggestion.
If you machine ‘goes’ to sleep while it’s streaming to the wifi, that could cause an interruption.
It can happen with the ‘network’ adapter or a usb port trying to save power…
Good luck
There’s an update coming. Some other threads have discussed it is in beta test.
