New controller problem
I have a Ortur LM 2 Pro S2 laser and Tech sent me a new control and cables. No instructions and I struggled for several hours and finally got it installed. I am having a couple problems:: when I power on and laser goes to home it continues to try and move for about 5-6 seconds to home and front left. I have the devise settings at X400 Y400 but when I check in the Move window the “get position” says X-600 Y-600. I have tried to change it several times but cannot get it to change. When I try to set the laser position it always goes to top right position. How can I change the left front home position ?
Also I cannot get the laser to turn on when I start a job.
I have contacted Tech support at Ortur an they have not been able to give me the answers that fix the problem. I have been trying for 4 days and am frustrated. Any advise would be appreciated
Memtenn60
I moved this to a more visible area, specifically for your machine…
@OrturTech, Gill is very good with these…
Hang in there…
you missed something
Could you take a couple images of EACH wiring point
Upload to youtube a smal lhoming video from center. Sound is 99% of diagnostics at times
I sent 3 pics and one video yesterday. Did you receive them as I have problems with Yahoo when I send pics etc.
Also: I think most of the problem is in the homing settings I have it set at left front with X400 and Y400. When I check position after homing it shows X at minus -600 and Y at minus -600
I have tried to figure out how to change it on the controller but can’t . In addition after homing , if I want to bring the laser to a position on the grid by using the “set laser position” feature no matter where I want to place it the laser goes to the top right.
Issue resolved, It was the limit switch. I moved it toward the back about 4mm and tested it and it homed correctly and the laser worked also the left front location now reads X00.0 Y00.o
Thank you for your assistance. Now I am back to lasering Yeh!
