completely new to this. I have been doing CandC work for a while but new to laser engraving.
My question is: do I need to put something down on the table top to protect it from the laser? What should it be made of?
I just went to Home Depot and bought a 3/4" smooth MDF board that was already cut 2’x4’ and it has been working great and have not burnt thru it yet.
Your diode has almost no power outside of its focus point. Anything that won’t easily melt will do, but I would steer away from metal as the last thing you want is a reflection. It might not cut/burn, but can do damage to your retina.
A sheet of glass, big floor tile, MDF, laminated chipboard, slab of granite, even a piece of 3mm-5mm acrylic
Thank you… makes sense
thank you…cheap enough.
