Im having the same problem Camera won’t work laser won’t burn and now I’m having problems even opening up LightBurn.
Just a small reminder, I had already reported that the files that were not working, I tried importing from the DXF file into a new file, in 9.21.
That “image” you suspect isn’t part of that DXF file, that was something I added after modifying the original file and saving it.
I will re-install 9.21 and try the things you asked.
Do you want me to click part of the file that has an “image” or just lines?
You have a Mac that isn’t communicating properly with your Ruida controller? If not, you aren’t having the same problem.
After update I realized that laser 2 is active all the time as laser 1, it copies the start and end of power of laser 1! When I start to work - only the first line (first cut) is not active on the second laser… from cecond cut up to end of job laser 2 is active and works in parallel with 1
(Ruida 6445) fw v15.01.15, Win7 x64
I’m using Mac pro running Mojave and connecting to Ruida to usb but I’m having the same issue on this post.
Mine does not have an image. Mine was a cut file and a fill file.
Should we wait for a Permanent fix or download the current update?
I, on the same evening, upgraded to a C3D board and updated the software version. My laser got all out of whack, couldnt position right, homing was screwed up and I could understand why. Racked my brain for two days trying to figure out where the problem was, either it was the new board or the software. Deleted the updated version, reinstalled v20 and bam, now it’s fine. I hope my experiences help a few good cutters out there.
Just upgraded yesterday to .21. Ortur LM2-20F system…Only technical issues ever had with .20, was when file saving it would lockup laptop until I restarted, only happened on occasion, my guess was a memory leak, as the service lbdialog was always locking up the task mgr after closing LB… Anyway, it just happened again, PLUS, NOW I keep getting dialog boxes at end of burns saying out of bounds, on files I never received them before. The file save error is a pain in the butt. Win 10, I7 laptop, (clone), 8g ram, plenty drive space. JFTR, I think Lightburn is amazing overall, great job guys!
I also started getting a notice to upgrade (again), but filename is same…
You’re getting an update notice because there is a patch. If you read carefully, you’ll see it says, “An update is available for your version (0.9.21)”
LBDialog isn’t a service - it’s actually the file open / save dialog box as an independent process. It’s done that way because some computers come pre-installed with file previewers that crash, and if they do, it now just crashes that dialog, not the whole program.
The “out of bounds” messages are most likely legit. If you post a shot of your screen I can probably tell you what’s wrong.
Did you report this to us?
Was not aware of a formal reporting process. New to this world and love LB, for future reference, where or who do I contact?
support@lightburnsoftware.com, or just posting here. Nothing in this release changed that should affect Smoothieware, so this is quite strange. If you install the current release there are a few things I can have you try to see if it’s the software or something else.
I thought it stange as well. I wasnt sure who to go to (LB or C3D) and I did not want to revert back to K40 Whisperer or Inkscape. Appreciate your responsiveness and hopefully will not have to report issues. Thanks a million Oz.
the reason wrote it was it didn’t say 21.a or 22…
on the file name to download
So I had the Mac Sur / Ruida 644XS issue not starting and program spontaneously shutting down. I had the new version update come through this morning for Version 0.9.22.
Just checking that I now have the latest version now after reading the whole thread?
Are we now encouraged to save our files as RD files?
Little shout out to Lightburn Oz for quick responses, as this thread sounded "challenging’
