Hi LB
Can you give us an estimate of when a New Version will be released? Also which additions/changes will be included?
Thank you
Hi LB
Thank you
Is there a feature or something you are looking for in particular? We are always working to produce the next release but donāt give hard release dates because if we find bugs weāll spend the time to stabilize things rather than try to rush it out.
Hi Rick. Sorry. Iām not rushing anyone, but Iām really looking forward to the version where āMulti-select nodesā and āSplit/Break Vectors where they crossā will be available.
That is the one thing that I miss when I switched from RDWorks. Multi Node Select.
I see you made a comment on our voting site some 3 months ago looking for these additions. Now with the cross-country move behind us, development work is picking up again. We usually donāt comment on timing or whatās coming, but maybe @LightBurn is willing to pull back the curtains and share some insight.
Neither of those are planned for the next release - Iāve had a bunch of changes for vendors. Multi-select for nodes is a pretty large architectural change, so that wonāt be fast, but I can look at the split / break crossings feature and see if I can make that happen.
I have seen you refer to changes made for vendors a couple of times, what does that mean? Are the laser manufacturers or controller makers asking for features?
Well, ālaser manufacturers or controller makersā are our customers as well and you know how we feel about customer requests. We love suggestions!
Do the vendors buy licenses to bundle with their hardware?
Essentially yes. Sometimes the features are specific to a particular machine and its hardware, but I try to make anything that isnāt machine specific available to everyone.
There are a few vendors already who bundle LightBurn - Darkly Labs is the biggest, with LightBurn being the software that ships with the Emblaser machines. Thunder Laser USA ships with LightBurn now, and as well as Aeon, and a number of smaller machine vendors. We have a few others circling.
That is excellent! The more that make LightBurn the default the better for all of us!
Now if there was just a way to make filenames longer than 8 characters. I suppose thatās not a problem when a PC is used to control the laser directly, but Iām still using a flash drive to load *.RD files into my TL Nova 24.
The limitation is in the Ruida controller itself, not LightBurn - Sorry - canāt fix that one.
Iām not enjoying that RD works has good/great nesting, while Iām doing it by hand on LB
RD has nesting? When did that happen?
You mean Iām guilty of believing someone else without checking? Damn.
Just downloaded the latest version right now to check.
That doesnāt mean Iām any less cuckoo for nesting!
I donāt know that it does or doesnāt. Theyāve had a button for ānestingā that just uses the grid array to fill a box with your shapes, and I think some people have claimed it had nesting based on that. They may have fixed it, which is why I asked.
That will be it. Iāve not used it for a long time and certainly not used any nesting feature. Someone mentioned RD Works nesting feature in a discussion of nesting.
Iām one of the sad that sits there and manually nestsā¦
Now that I have worked out how to make Deepnest work properly I occasionally use that.
So far I like SVGNest over DeepNest. Iāve (slowly) started working on it, but itās not simple.
SVGNest was the cloud-based predecessor to Deepnest, wasnāt it? Same author? Heās given up on Deepnest - so many unattended issues.
Iām still unused to āunlimited internetā plans and tend to downloadable tools, but will give SVGnest a go.
I had to go and adjust my and my wifeās phones the other day to turn on all the wireless features as we had lived for so many years with expensive and limited plans in the third world
