Hi! newbie here trying to setup the Ortur Laser master 2.
ive set up the laser which seems to power up fine but I can’t connect it to Lightburn, I’ve followed the manual steps but where it shows ‘devices’ I have no drop down to select the com port it just says (choose) as if its not recognised.
ive checked system information on my Mac and it shows the laser here so guess the USB works ok?, I have seen people having issues with 1.0.06 version of light burn and Macs, could this be the issue?
this is my first setup so cannot confirm the laser worked before but its brand new, I have literally just put it together out of the box.
I’m going to try om windows. also but can’t try this until next week and ideally wanted to use my Mac to operate
This sounds like the driver is not getting loaded. You should not need to install a driver for this controller but weirder things have happened.
Things may get a little involved at this point so let me know if you want to step away from this. I no longer daily drive a Mac so I’m also mostly working blind here. Hopefully someone keeps me honest here.
Check if drivers exist or potentially conflicting drivers. Run this in terminal. You’ll need to provide your credentials. Please capture the output:
