I bought the following camera: 5MP USB Camera Module OV5648 1080P UVC 170 degree Wide Angle Lens CMOS MJPEG UVC HD USB mini board YXF-QQSJ-8809-V1-170-R
The camera displays as ‘lightburn camera’ in my devices.
In the lightburn program it is selectable, however I get no image when I choose it.
My built in webcam however does display an image so I know that something in there is working.
i started the other thread, i did get it sorted in my case it turned out to be Autocad Suite causing a conflict, i uninstalled it and my camera started working. However i had no image on any camera including webcam when selected in lightburn, now they all work. If your usb camera is working ok then you should be able to select it as a webcam, if you still get no image when you try to use as webcam then you have a faulty with camera or driver.
Thank you for getting back to me so quickly!
I am using windows 7.
I have attempted to install UVC USB drivers but I don’t really know what I’m doing in this regard.
I went to this site to test the camera and make sure that it is functioning: https://webcammictest.com/
I got video on this site, so the laptop is interfacing with the camera.
Do you have any suggestions based on the above data?
Perhaps where the UVC USB drivers you are referring to would be located for windows 7?
Well, I think we’re still taking auditions for Dorothy, the Wicked Witch of the East (no speaking parts), and the big blond in the purple dress in the Super Freak video.
I have tried all those things mentioned I’ve even tried it on a windows 7 machine. Each time it’s showed up in the list as Lightburn camera however it doesn’t give any image, only a black screen.
Does it show up on any camera application? In MacOS for example, if you run the camera app you should be able to choose the LightBurn camera. If that doesn’t work, message me directly.
