PC lin. Mint 20, 64 bit, Cutter K4 with M2Nano Board, Cohesion3D board with “Ribbon Cable + Screw Terminal Power Supply” Variant,
LightBurn 1.2.01, built Fri 2022-07-22 @ 05:05, K40 came with M2Nano Cont. attempting to replacing with Cohesion3D cont.
The LED lights show…
VMO
3V3 red on
L4 green on
L3 green flashing
L2 green flashing
L1 green on see attached
Actions:-
Device Create Manually run, using Smoothieware Cont etc. Console message “waiting for connection”,
Earth stake added resistance between stake and K40 chassis 0.4 to 0.8 ohms
New USB lead was 3m now 1.5m
SD card re-written, firmware extension renamed to “FIRMWARE.CUR” on power-up.
Still awaiting connection, help with this connection appreciated…
The
If you can answer in the positive for all 3 then you should have everything you need to connect. Right click-on “Devices” button in Laser window to force reconnect or pull-down the Ports field and manually select the relevant serial device.
Terminal not my preferred option.
Am a bit confused. here is summery from the terminal that i just ran…
revor@trevor-System-Product-Name:~$ lsusb
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 006: ID 1d50:6015 OpenMoko, Inc. Smoothieboard
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 006 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
trevor@trevor-System-Product-Name:~$ sudo adduser $trevor dialout && sudo adduser $trevor tty
adduser: The group `dialout’ already exists.
trevor@trevor-System-Product-Name:~$ dmesg | grep -i smoothie
[ 240.828837] usb 2-1.6: Product: Smoothieboard
[ 1333.966533] usb 2-1.6: Product: Smoothieboard
[12076.094319] usb 2-1.6: Product: Smoothieboard
[12081.238393] usb 2-1.6: Product: Smoothieboard
Lightburn shows:-
Waiting for connection…
User re run
trevor@trevor-System-Product-Name:~$ sudo adduser trevor dialout && sudo adduser trevor tty
[sudo] password for trevor:
The user trevor' is already a member of dialout’.
The user trevor' is already a member of tty’.
trevor@trevor-System-Product-Name:~$ ls /dev/smoothie*
ls: cannot access ‘/dev/smoothie*’: No such file or directory
Success berainlb, i can go to Home and Origin, just have to get used to switching from Whisperer to Lightburn, thank you for your patience and help…Trevor
To tell the truth don’t exactly know, just went out to workshop with the intent of doing battle with the setup again, loaded Lightburn and to my surprise i heard the X and Y axis fire up and moved to Home.
For your interest a couple of pics, had a hard landing rebuilding part of fus…
