Nvum v2 Controller?
Dears
I do have this controller NVUM v2 and i would like to use lightburn software, but i want to know if the software supports this card or not ?
Appreciate your reply
One way to find out is to download Lightburn and see.
It’s a Mach3 based controller…
Then follow @Dskall advise about the trial version.
You can find other threads on the Mach3 board, by searching the site for Mach3…
I pulled the manuals.
I haven’t seen this controller before but it’s interesting.
I asked the team. I don’t believe we’ve tested that controller yet.
Since that is a Mach3 Controller LightBurn and MillMage are unlikely to ever directly control it. You can use the LinuxCNC profile currently to produce g-code for it but it will need some slight tweaks that you will need to figure out for your specific machine.
In 1.5 we will be releasing a “Custom G-Code” type that you will be able to specify what is included in blocks like “fire” and “tool on” to more easily support controls like this and need less post processing.
