When I engrave multiple parts using the Offset Fill option, the laser will move around the bed engraving small parts of the offset fill instead of completing one item then moving on. The fill shapes/groups options are greyed out.
Thatās nice, dear.
Did you have a question or is this informational?
How do you make Offset Fill completely fill the shape before moving on?
Hi, select the project in the cuts/layers and select āfill shapes individuallyā.
so a question on top - what is offset fill, and why would one use it?
There lies the answer, take it off offset fill you can then use the āfill shapes individuallyā.
(hopefully)
It is well described in the documentation
https://lightburnsoftware.github.io/NewDocs/CutSettings-OffsetFill.html
If youāre using Offset Fill for something with lots of shapes, you probably shouldnāt be. Itās intended for simple things like large open frames, as an alternative to flood fill. What does the design look like?
These are logos made up of bold text with an contour being filled with the offset engrave spaced enough to give a cool effect. The logos repeat multiple times on a sheet. It would be nice to be able to finish one logo before moving 6 inches over to do each small section individually.
Iāll add a request to add support for the different fill groupings for Offset Fill.
Could you link the request here? Thanks!
I have no way of connecting you to our internal bug database, but I have linked the thread so I can post back here when itās done.
I didnāt know you were talking about your internal bug database; I was thinking you were talking about the feature request side of the site. Thank you!
This is completed for the next release - I havenāt enabled the choosing of different types, but Iāve made āfill individuallyā the enforced setting because itās faster and cleaner. Thereās no real need to use āall at onceā or grouping with an offset fill.
