Hello guys,
I recentry got a quite big size laser machine which uses old RZNC-0601 Controller.
This is the spec. I found in Aliexpress
1.With DSP technology, the increase of cut-to-length precision can be obtained as it offers well-timed and high control accuracy;
2.With Embedded Control technology,easy to install and maintenance free;
3.With humanized operation interface,control panel is simple to operate;
4.Built-in 128M memory,support directly to working from the U Flash;
5.With mobile storage technology,do any job without computer;
6.Support any size file as G-code,Plt,NC,CNC,MMG and so on;
7.Support linear interpolation and circular interpolation;
8.The RichNC offers I/O,pulse,signal diagnostic capabilities;
9.The RichNC offers multi-coordinate function,keep memory 9 differents coordinate;
10.The RichNC offers multi-point function,keep memory 6 differents working-point;
11.The RichNC offers 2-16 differents speed for spindle control;
12.The RichNC offers built-in checks of the correct entry and processing of data;
13.The RichNC offers power off memory working-point function;
14.The RichNC offers redo the last job as the same as last time;
15.The RichNC offers hardware and software machine size limited;
16.The RichNC support multi-language display;
It seems like DSP based controller usually used for CNC and I have very limited informations about it.
My goal is to control the machine from lightburn, however it is not on the Lightburn compatability controller list.
If someone has a expirience can give some advise how I can control the machine from Lightburn it would be much appreciated.
Thanks in advance!!
