OLF 170. [MSG: Flame detector active,Ambient infrared value0
I have seen others post about this, however looks as I need updated firmware. How do I get that? Thank you
What makes you think you need to update your firmware?
Thats a message , not an error
From others, It is not just a message but error code. I get a [MSG:’$H’|’$X’ to unlock] I don’t know how to unlock it though. I have to reset it always.
would help greatly if you could post the console log that you are getting please
What’s this “flame detector”?
I’d often wondered about such a thing, it would be handy.
Our Universal Laser Systems machines had a “fire detector”. I was never certain but looks like it is probably just a thermal fuse that would only open if the machine were burning down. Weirdly ULS added an alarm that requires batteries, and then prevents you from running the machine if low. I’m not sure how the laser could be on fire while NOT plugged in?
Anyhow, I’d LOVE to have an optical flame detector that actually works.
@OrturTech Ok I think it is shock jog movement error not flame. here is the log
Waiting for connection…
ok
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master 2 Pro S2]
[OLF: 183]
[DATE:11:19:45 - Sep 1 2021]
[VER:1.1f(ESP32).20210403:]
[OPT:VNMZHSL,35,1024,3]
Target buffer size found
ok
Homing
ok
$0=5.0
$1=100
$2=0
$3=2
$4=7
$5=7
$6=1
$10=2047
$11=0.050
$12=0.002
$13=0
$14=6
$15=0
$16=1
$17=4
$18=0
$19=0
$20=1
$21=1
$22=43
$23=7
$24=600.000
$25=3000.000
$26=100
$27=3.000
$28=0.100
$29=0.0
$30=1000.
$31=0.
$32=1
$33=1000.000
$34=0.000
$35=0.000
$36=100.000
$37=0
$39=1
$40=1
$41=0
$42=1
$43=1
$44=3
$45=4
$46=0
$56=1.000
$57=1800.000
$58=395.000
$59=6000.000
$60=0
$61=0
$62=0
$63=3
$64=1
$65=0
$259=0
$260=70
$261=70
$262=230
$263=30
$264=0
$265=100
$267=0
$100=80.000
$101=80.000
$102=400.000
$110=10200.000
$111=10200.000
$112=1200.000
$120=2200.000
$121=1800.000
$122=2200.000
$130=400.000
$131=400.000
$132=50.000
ok
$33=1000
ok
$0=5.0
$1=100
$2=0
$3=2
$4=7
$5=7
$6=1
$10=2047
$11=0.050
$12=0.002
$13=0
$14=6
$15=0
$16=1
$17=4
$18=0
$19=0
$20=1
$21=1
$22=43
$23=7
$24=600.000
$25=3000.000
$26=100
$27=3.000
$28=0.100
$29=0.0
$30=1000.
$31=0.
$32=1
$33=1000.000
$34=0.000
$35=0.000
$36=100.000
$37=0
$39=1
$40=1
$41=0
$42=1
$43=1
$44=3
$45=4
$46=0
$56=1.000
$57=1800.000
$58=395.000
$59=6000.000
$60=0
$61=0
$62=0
$63=3
$64=1
$65=0
$259=0
$260=70
$261=70
$262=230
$263=30
$264=0
$265=100
$267=0
$100=80.000
$101=80.000
$102=400.000
$110=10200.000
$111=10200.000
$112=1200.000
$120=2200.000
$121=1800.000
$122=2200.000
$130=400.000
$131=400.000
$132=50.000
ok
ok
<Idle|MPos:0.000,0.000,0.000|Bf:35,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:73,64|VA:23726,0|Ov:100,100,100|A:S|H:1,7>
ok
Starting stream
Stream completed in 0:00
[SC7A20:(235) Shock and Movement detected! Check TroubleShooting Section in User Manual.]
Ortur Laser Master 2 Pro S2 Ready!
OLF 183.
[MSG: Flame detector active,Ambient infrared value:64]
Grbl 1.1f [’$’ for help]
[MSG:Caution: Unlocked]
ok
<Idle|MPos:233.950,229.587,0.000|Bf:35,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:64,77|VA:23684,0|Ov:100,100,100|A:S>
ok
Starting stream
OLF 183.
[MSG: Flame detector active,Ambient infrared value:80]
ok
<Idle|MPos:238.100,226.275,0.000|Bf:35,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:80,80|VA:23712,0|Ov:100,100,100|A:S>
ok
Starting stream
[SC7A20:(260) Shock and Movement detected! Check TroubleShooting Section in User Manual.]
OLF 183.
ok
<Idle|MPos:253.388,246.738,0.000|Bf:35,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:68,77|VA:23729,0|Ov:100,100,100|A:S>
ok
Starting stream
[SC7A20:(240) Shock and Movement detected! Check TroubleShooting Section in User Manual.]
OLF 183.
ok
<Idle|MPos:254.100,238.375,0.000|Bf:35,1024|FS:0,0|Pn:PS|CL:0,100|PS:2,1|ER:68,81|VA:23701,0|Ov:100,100,100|A:S>
ok
Starting stream
Starting stream
Layer C00 Pass 1 of 2
Layer C00 Pass 2 of 2
OLF 183.
My table is clamped down so I know it is not moving. IMG_0077
You are definitly getting a JUST at the boardeline value
In future revisions i asked Ortur to loosen up this value a bit they are causing more trouble
Try this in console
$RST=*
press enter
You will read [MSG: Restoring defaults]
Then
$262=750
Press enter
Retry file please?
Thank you, I will try and update you.
@OrturTech I just wanted to let you know that it worked. Whatever that did I am getting full successful jobs.
