Omtech k40 power supply issue
hello there, this is my first post so i hope im in the right place and following rules , i have omtech k40 and the tube died because of my stupidity and cold weather , so i got a new tube that 45-50w and a new power supply but they did not send me a myjg40. so the new supply has different connections and it does not have a 24v output either for the stepper , so its not gonna work without some alterations.
so the tube is installed and fires with the new supply using just the test button so thats ok , when testing with the old power supply it fires a little and screams like a cat also turns off my pc monitor! although the old supply(myjg40w) was working fine with the old tube, so i guess it doesn’t have the capacity to run new tube or its half dead, when connected to the controller and all the other wires it does nothing , but when testing just the tube it goes a nuts.
i am clued up somewhat . but a diagram would ease the pain
is there anyway to use the 2 supplies in conjunction ? so the blue one with 24v for stepper and black one for laser , or not worth the risk , thankyou for your time
I wouldn’t use both. I’d get a like-for-like replacement, they’re widely available and not very expensive or you could ask OMTech for a more suitable one.
Sending only the HV PSU when you had a combination PSU isn’t a suitable replacement part and certainly shouldn’t be considered end-user swappable (in my opinion).
That said if you’re determined I’d recommend simply getting a smaller dedicated DC PSU for the steppers and controller power. You can find the pin-outs for PSUs online or usually they are marked on the PCB.
I hope that helps. Warning - PSUs output extremely high voltages and contain capacitors and other components that can retain high amount of power after disconnection. Unless you really know what you are doing do not dismantle a PSU.
Thanks for your input , i can get a 40w like for like but not a 50w unless from omtech its not due in till late february, do you think a 40w could run a 45-50w tube ? Or maybe wait for an omtech one , or could i buy a 60w to run a 50w tube ?
Like this ?
thanks
ok so i bought a new psu that can work this unit ,like for like but theres seems to be a problem ,when i connect the 5v in connector the psu led does not light up , and lightburn cannot fire it , if i disconnect the 5v cable i can fire it from the test button and it lasers ! so has the board died ,everything else is normal, i also checked the grounding between board ,laser and psu its all good , it has a monoport board and its detected by lightburn and acts like its doing the job on that side , the p+ g is connected to safety switch on door and its ok , some insight please ,thanks
so with 5v connector connected > no psu light
with it disconnected> light ok on psu
What light, the power light? Does this PSU have a light for P (protection)? Have you changed any of the headers? Do you have a comparison photo of the two PSUs? Are they absolutely the same, is there any extra capacitors or resistors on the original one?
Note that 50W and 40W can be deceptive. Unless you had a tube at least 800mm long you’re not likely getting an agreement power of 50W possible a peak power. Laser cutter sellers have a huge incentive to overstate the power of their cutters. If its like for like and you’ve not changed anything around you should be able to get some guidance from the supplier.
Obviously it is fairly difficult to coach you through this remotely and without access to the original wiring setups used by the supplier etc.
hi, resolved i had the 5v and the negative blue wires in the wrong way , but thankyou for your time, HAPPY NEW YEAR !
Thank you for letting us know. I figured it might be something like that.
