Omtech laser axis grinding
Lets get a little more specific here…
You stated you swapped the motor controller cables… did you do both the input and the output?
The idea is to follow the signal, output of the Ruida goes into the motor drivers. This is the first cable to check. If you swap them at the Ruida or the drivers, it doesn’t matter as long as it’s the output of the Ruida and the input of the motor drivers.
I’m suggestion swapping the output of the motor drivers with the input of the motors… It’s obviously easier to swap them at the drivers than at the motor.
I just want to make sure you are doing output of this to input of that for a good debug of the issue.
If you can read the placard on your motor drivers, it will show you the input/output sections… like the one I posted…
It’s sounding like you swapped both the connectors in both of the motor drivers…
You can swap the green or red outlines at either end, as long as you do only one end. On the motor driver you want to swap only the outputs (green).
Did this help or add to the confusion?
