The outputs can sink up to 500mA, depending on what Ruida manual you have… This current limit is clearly for allowing solenoids to operate through the Ruida.
The Puxy is a 5V supply. I know of nowhere it states this can supply 500mA. I’ve looked many times. If you can confirm that it will source 500mA, I’d love to have it…
It’s called Puxy, which means a pull up for x and/or y not that it’s a 5V 500mA supply voltage for external electronics… If so, I doubt many of these machines would have separate 5V supplies available like they do. Your 24V supply may have a suitable 5V output.
Most of these machines use 24V hall effect, with a very straight forward connection scheme.
The - inputs are for home whereas the + is for limit switches… You are not using limit switches so only the - inputs are applicable here.
Many of these machines use home switches as limit switches after the machine homes properly… The Ruida has an extra set of switches (4), one at each end of each axes to determine if the machine has gone outside of the work area…
If you wanted to implement both home and limit, it would take 6 switches/wiring.
You should only use LmtX- and LmtY- for home switches.
Make sense?
Don’t quite follow you here… if you want it work off 24V, then you need a resistor for each signal or both will illuminate if in series…?
I don’t suggest optical home switches… I’ve lost some good jobs because of debris ending up triggering the sensor and halting the job with a lost location, so I can’t restart it.
I’ve replaced all of them with Hall Effect type switches.
You wouldn’t think this would be a problem with lasers, but the simple fact is my lens is in a nozzle with air flow, it still gets dirty just like everything else in the machine… There is nothing to prevent smoke and/or other debris from sticking to the optics… how do you clean the optics?
Can you mount and use this type of switches… these are on my machine…from Amazon
Good luck
