Option to not return home
Hi,
I am running a job and am positioning text manually at different points on the piece. Is it possible to have the laserhead not to return home after a cut.
That way, I can move it to the next position which is a few cms away rather than having to bring it from home?
Thanks
Steve
I think this will help you,
https://lightburnsoftware.github.io/NewDocs/CoordinatesOrigin.html
It depends on your controller type. For a gcode controller (grbl, smoothieware, etc) go to Edit > Device Settings, and uncheck ā€œReturn to finish Positionā€
DSP controllers like the Ruida will generally also return to the origin - either the global origin (where it homes to) or the user origin - So if you are cutting based on ā€œUser Originā€ it will always return there.
Darkly Labs requested that the Emblaser 2 always return home, and we don’t give the option to set a different return point. If you use ā€˜Current Position’ mode, the laser will return to the starting location so the job is repeatable, but that’s it.
Ok. Thanks for the responses.
I used the ā€œSet Finish Positionā€ to move the home temporarily and that worked.
Steve
