I have two problems and I am not sure what is causing either one. I am using a Mac mini with the latest software and all new high quality USB cables. I have two lasers a Yora At Home 6550 3w which generally runs perfect but still shows the out of bounds all the time. And I have a new Ortur 20W which is the problem I am constantly getting the out of bounds and also getting an alarm 2 or alarm 4. I am including first the Grbl then the tech support readoutI had just completed one 4x4 tile and I noticed it stopped and did not go back to where it started or go home. Then I had to restart the Ortur and then click devices to bring up the screen and select the Ortur again. Once I did that everything appeared correct. The fire button worked and I set my next tile to be produced and clicked on start. A warning came up that said cut might be out of bounds-continue anyways yes or no. I select yes and it immediately hets the alarm 2 and does not move. I was using current position, I then tried user origin with the same results. I get the same out of bounds on all three including absolute coordinates. The problem with absolute coordinates is I do not know how to set it to start where I want it to start on the xy axis.
<Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
Starting stream
Layer C00
ALARM:2
On or near line 157787:
Stream completed in 58:41
[MSG:Reset to continue]
Waiting for connection…
Port opened, waiting for response.
ok
ok
ok
ok
Exceeding the maximum exposure time of the laser!
In weak laser mode, the maximum time allowed is 100 second.
None weak laser mode , the maximum time allowed is in the range from 10 to 60 second , according to the power .
Reset Grbl.
Ortur Laser Master 2 Ready!
OLF 137.
Grbl 1.1f [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
ok
ok
ok
ok
ok
ok
ok
ok
Starting stream
Stream completed in 0:03
Starting stream
Starting stream
Starting stream
Starting stream
ok
Starting stream
Layer C00
ALARM:2
On or near line 4:
Stream completed in 0:00
ok
ok
ok
ok
ok
ok
ok
Starting stream
Starting stream
ok
Starting stream
Layer C00
ALARM:2
On or near line 4:
ok
ok
ok
ok
ok
ok
ok
Starting stream
ok
Starting stream
Layer C00
ALARM:2
On or near line 4:
ok
ok
ok
ok
ok
ok
ok
Starting stream
ok
Starting stream
Layer C00
ALARM:2
On or near line 4:
ok
ok
ok
ok
ok
ok
ok
ok
Starting stream
Layer C00
ALARM:2
On or near line 6:
ok
ok
ok
ok
ok
ok
ok
Starting stream
Layer C00
Stream completed in 0:02
ok
ok
ok
ok
ok
ok
ok
ALARM:3
ok
OLF 137.
ok
Here is the tech support info
[Support Data Redacted]
