Hello,
is it possible to activate the LaserGRBL feature “Boundary” in LB to better align an object?
The option “Fire” (laser on with minimal power) in LB does not work in motion to align the outer contours of the object.
Thanks
Hello,
Thanks
I tried that but I sill only have one button which is the fire button?
Being pointed at below by the mouse:
You need to restart LightBurn for it to appear. Once it’s there, you can set a power value and check to make sure you can see the beam. Once you’ve done that, holding the Shift key when you click one of the Frame buttons will activate the laser.
