ortur laser master 2 has stopped engraving, using lightburn. The blue laser light is on and the module goes through the motions but does not engrave. I did an interval test, and it engraved the test.
You’re saying the interval test did work but that you’re unable to to engrave your own jobs?
If so, can you take a full screenshot of LightBurn with your design loaded and Cut window showing?
Are you saying to take a screenshot of the completed interval test?
No. I’m asking to load a design that you’re unable to engrave based on your stated problem.
Also, if you can confirm that the interval test does actually engrave but that your own designs do not.
Thanks, I’ll give that a try tomorrow!
