Hello, I have an Ortur Laser Master 2. The plastic piece the limit switch is on broke. The plastic piece holds one of the timing/drive belt tension, and also has the limit switch on it. Is there anywhere online to buy replacement parts for the Ortur Laser Master 2 ??
Like Sasquatch says, you should contact Gearbest and ask them to send you another one. It may take a while though. If you know someone with a 3D printer, they might be able to create one for you. Good luck. Hope you get another one soon.
