Ortur Laser Master 3 keeps beeping, I cannot get it to quit when using Lightburn. I was using it wireless with Laser explorer wireless with the zip drive connected and it does not beep, only when I take the zip drive out and connect it with usb to my computer
Do you have the SD card inserted? If not, I suspect that’s expected.
I do not have a the sd card inserted, I have the USB cable hooked to may computer instead
My understanding is that the SD card is required even with USB connection. It’s apparently used for caching.
Yes - it’s required as per the documentation if I remember correctly, though I can’t confirm it caches.
