Ortur laser master 3 Upgrade to lu3 20a
Hi all. I have an OLM3 with a 10 watt module. I decided to upgrade and bought a kit with a 20-watt module (LU3-20a). The kit includes exactly the same power supply as for 10 watts (24 volts and 4 amps). On the module itself it is written that 24 volts and 6 amperes are needed. Tech support says that if you have an OUC 2.0 adapter, you can use a 4 amp power supply. It seems to me that the laser will operate at lower power. Maybe someone who has such a module can share their experience. I think you need to buy a 6 amp power supply
The “tech” was right
You are intended to use the small board and connect BOTH power adapters
One to the machine other to the OUC board
However, if you inspect your machine and your motherboard comes with a fan you can buy a 8amp 24v power adapter and plug module direct and just one power adapter
thanks for the answer
