Ortur Laser Master Pro 2 Upgraded Z-axis
Hi there, ive been using lightburn for a couple months and im still no expert so thats why im here, I brought the Z axis upgrade and was wanting to know is there any settings that need to be adjusted as I noticed I had to attach a spacer for the home stop switch to stop the laser head from going to far past zero? Im assuming you have to as the grid size is 400x400 but now the distance would be shortened going home. the laser head seems to have moved slightly out due to the depth of the new addition.
You probably only need to change $131, Y Max Travel, in Edit->Machine Settings. Reduce it by the thickness of the Z Adjuster.
Be sure to save your old configuration FIRST!
Then, make the mod, and then Save To Machine. You should repower the Ortur and restart LB before using. When you restart LB you should see that your workspace is the new dimension you entered.
