Ortur LM2 Pro - doesn't turn off after project / between cuts
I have a problem with my laser, it doesn’t turn off between cuts, or after he finish his job… any idea?
If I will put a image in lasergrbl, it Will do it normal… but any project, it will make it like that
LU2-4-SF
Ortur Laser Master 2 pro
Could be a bad motherboard.
@OrturTech
Very uncommon on the pro, in fact i dont think i seen it happen before
Ortur Customer Support – Ortur Support Ticketing System we need to go a bit deep in the diagnostics please @aadryaan94
Thank you, I was already done that, someone was reply, I was done some measurements, checks of wires, and he said is from module, so he will send me a replacement… that was about 1 week ago. I was send few more emails, nobody answer… so now I can’t use it, and nobody from ortur helps me… that’s why I try to get a fix from here.
Laser module was have some scratches, so it wasn’t new. Guy from ortur support was saying about transport… but is not from transport, is from use. So it wasn’t new. And another sign of use is motherboard… USB port is not fixed… is moving a lot
Try putting $32=1 in the console tab
Nothing, some problem…
