Hi,
Total newbie here and not sure what category this should go under. but my issue is that the laser comes on way too hot and before its supposed to, as well as stays on after the project is done, burning a line across the piece and scrap baseboard. It also comes on way to hot when I do a test fire. I have it set to 1% for the test fire framing function and its burnt a hole through a 1/4" piece of plywood. It also doesn’t turn off when the firing is done for approx. 10-15 seconds, unless i pull the plugs. it just sits there boring a hole into my scrap board. I am running a Ortur LM2 20w on an older PC running windows 8.
Any help is appreciated and thank you in advance
