Ortur master 2 pro s 2 issues with flame alert
hi all i have been back and forth with ortur about thus issue
flame alert keeps popping up during jobs and even when the laser is not running they have directed me to disable it and i have done but it still goes off please see my settings hoping someone can help
things i have done to try and resolve it
tape over sensor covered it fully no light gets in at all
have a fan pointed directly at it
built a box and have a inline fan pulling fumes and heat out
firstly see settings from in console i tried to run a job it worked for about 2 minutes then stopped with this error
Waiting for connection…
Project loaded in 10 milliseconds
ok
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master 2 Pro S2]
[OLF: 188]
[OLH: OLM_ESP_PRO_V1.2]
[SN: 7EC8F91F7D1E119E30A2C7568B108D80]
[OLM:GENERAL]
[DATE:12:47:49 - Mar 5 2022]
[VER:1.1f(ESP32).20210403:]
[OPT:VNMZHSL,35,7680,3]
Target buffer size found
ok
Homing
ok
Starting stream
[MSG:Pgm End]
Stream completed in 0:00
ok
Starting stream
[MSG:Pgm End]
Stream completed in 0:02
ok
ok
<Idle|MPos:95.000,220.000,0.000|Bf:35,7679|FS:0,1|Pn:P|CL:0,100|PS:2,1|ER:2,2|WCO:0.000,0.000,0.000|VA:25014,190|Ov:100,100,100|A:S|H:1,7>
[GC:G1 G54 G17 G21 G90 G94 G49 G98 G50 M3 M9 T0 F100 S1.]
ok
Starting stream
[MSG:Pgm End]
<Idle|MPos:100.000,220.000,0.000|Bf:35,7679|FS:0,1|Pn:P|CL:0,100|PS:2,1|ER:2,2|WCO:0.000,0.000,0.000|VA:25070,180|A:S>
ok
Starting stream
[MSG:Pgm End]
ok
ok
ok
<Idle|MPos:98.000,220.000,0.000|Bf:35,7679|FS:0,0|Pn:P|CL:0,100|PS:2,1|ER:30,14|WCO:0.000,0.000,0.000|VA:25014,136|A:S>
[GC:G0 G54 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F100 S0.]
ok
Starting stream
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 5:
[MSG:Reset to continue]
ok
Ortur Laser Master 2 Pro S2 Ready!
OLF:OLF 188.
OLH:OLM_ESP_PRO_V1.2.
OLM:GENERAL.
[MSG: Warning: Flame Sensor Disabled by User OverRide]
[MSG: Flame detector active,Ambient infrared value:30]
Grbl 1.1f [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
Starting stream
Layer C02
Stream completed in 6:57
this is my dollar dollar settings
ok
$0=5.0
$1=100
$2=0
$3=6
$4=7
$5=7
$6=1
$10=2047
$11=0.050
$12=0.002
$13=0
$14=6
$15=0
$16=1
$17=4
$18=0
$19=0
$20=1
$21=1
$22=1
$23=7
$24=600.000
$25=3000.000
$26=100
$27=3.000
$28=0.100
$29=0.0
$30=1000.
$31=0.
$32=1
$33=1000.000
$34=0.000
$35=0.000
$36=100.000
$37=0
$39=1
$40=1
$41=0
$42=1
$43=1
$44=3
$45=0
$46=0
$56=1.000
$57=1800.000
$58=395.000
$59=6000.000
$60=0
$61=0
$62=0
$63=3
$64=1
$65=0
$100=80.000
$101=80.000
$102=2124.000
$110=10200.000
$111=10200.000
$112=600.000
$120=2200.000
$121=1800.000
$122=200.000
$130=400.000
$131=400.000
$132=100.000
$259=0
$260=70
$261=0
$262=750
$263=0
$264=0
$265=50
$266=100
$267=0
$268=0
$269=0
$270=5120
ok
What we see here isn’t the Flame Detector alarm. This is just a friendly reminder that you have tweaked / disabled the setting and basically shut the sensor off.
This is a very nicely optioned engraver.
Just to confirm, Your laser engraver is working, then it stops, then the above message appears?
This is your engraver restarting. This can be caused by a power interruption, or a communication interruption. Are you using a short, Shielded USB cable with the Ferrite Beads on it?
Ortur has released a firmware update in March this year.
This may address the symptoms you’re observing.
Please update your Firmware to the latest version:
https://ortur.tech/latest-firmware/
I will move this into the Ortur laser section where you’ll get more constructive advice from the community.
hi and thanks for reply i am using the cable that came with it not ever had any issues
and yes this happens when the laser starts a job
@OrturTech - Hey Gil, The engraver seems to restart shortly after starting a job (with no error message). Is communication, power or firmware the next likely path toward diagnosis?
My OLM2 was randomly stopping until I found out about the static issue.
They have a kit available for the asking that will properly ground all the parts of the frame. It may help. The poly wheels rolling on the belt and the anodized frame build up a heck of a static charge that, when it discharges, will reboot the controller, sometimes without shutting the laser off…
The solution for that (and it may or may not be your problem) is adding a wire to every part of the frame and bringing these back to a common ground.
i have a 800×400 bed size it is set as 777×390 and has never been changed
if i tell laser to go upwards 400m thats fine it will do that but if i put 410 it wont go any were then says this
ok
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[OLF: 188]
[OLM:GENERAL]
[DATE:12:47:49 – Mar 5 2022]
ok
Homing
ok
<Idle|MPos:0.000,0.000,0.000|Bf:35,7679|FS:0,0|Pn:P|CL:0,100|PS:2,1|ER:0,0|VA:24941,0|Ov:100,100,100|A:S|H:1,7>
ok
Starting stream
ALARM:2
On or near line 2:
ok
OLF:OLF 188.
OLM:GENERAL.
[MSG: Flame detector active,Ambient infrared value:0]
[MSG:’$H’|’$X’ to unlock]
ok
see device settings its says what size bed i have
I’m curious about something, your X max travel (from your $$ output) is $130=400, but in Device settings it’s 390. Your Y max travel is $131=400 but in Device settings it’s 777. These numbers should match (someone please correct me if I’m wrong), so what I’m wondering about, is your work area 800mm deep (Y axis) and 400mm wide (X axis) or is it 400mm deep and 800mm wide? I’m just trying to visualize your setup.
