Ortur master 2pro 10watt su started to frame really slow for no reason
Went to start a new burn today set up file that i have used in the past hit frame and it moved very slow speed. Burn and home runs normal speed. Tried different files checked all plugs and adjusted belts. Upgraded light burn… nothing seams to work.
Change frame speed by adjusting jogging speed in Move window.
If you recently upgraded there’s a bug where the speed won’t be saved automatically upon close.
You can workaround that by going to Edit->Settings and then click Okay apparently this should save the setting.
that did it thanks
