Ortur Rotory setup
Im setting up my Ortur Rotary attachment.
Ive changed all the settings as per you tube videos,
Im trying to etch a 3" clip art image onto a glass jar, when I set it off to frame the image the Z axis moves all the back to the frame and doesn’t stop once it reaches the back frame. Help
Be sure you have the homing feature turned off. Also, check the “enable rotary” feature is turned on.
This tutorial explains everything about setting up your rotary.
