I’m about to install the subject lifting device onto my Ortur Laser Master 2 Pro, and I note in the assembly manual for the device that I may have to adjust the firmware parameters according to instructions using LaserGRBL software.
Problem: I’m using LightBurn software, and I’m not using LaserGRBL software.
Is there a set of instructions to check and adjust the recommended parameters using LightBurn.
Installed the Z-axis Lifting Device following directions. Wrote a very simple macro through the Console with recommeded GCode supplied with the directions provided by Ortur:
I installed the aftermarket Ortur Z-axis Lifting Device to the original Ortur Laser Master 2 Pro. In the instructions, it states, “When Z-axis Lifting Device assembled, the mismatch of increased weight and acceleration may affect movement accuracy. Then, you need to adjust the firmware parameters according to the following instruction.”
I cut many leather pieces and I find that the accuracy of the cuts is better after changing the original setting ($120 = 2200.000 and $262 = 290) to those recommended.
I also noted that sometimes the original firmware setting revert back, hence the macro.
