Pas de connexion machine
Bonjour j’ai essayé par tous les moyens de connecter la machine mais au laser omni 1 j’ai regardé tous les détails dans le livre mais impossible que la connexion se fasse entre la machine et l’ordinateur et est-ce que quelqu’un a eu le même problème j’ai changé le câble USB on pensant que ce serait celui-là mais rien n’y est fait il n’a toujours pas été reconnu j’ai tout bien installé merci de votre aide
Please do not double post the same problem. You can edit the original posting if needed.
Hello, I tried every way to connect the machine, but to the Omni 1 laser. I looked at all the details in the book, but it’s impossible to connect between the machine and the computer. Has anyone had the same problem? I changed the USB cable, thinking it was the one, but nothing worked. It still wasn’t recognized. I installed everything correctly. Thank you for your help
The Omni has a DSP controller. Did you search the Forum to see if it is compatible with Lightburn?
You said you "tried every way, but did not tell us what those tries were. You also made no mention of any error messages observed.
