Laser works for a while and then just stops moving mid project. Shows still running in software, still connected and showing working in console, software version 0.9.20
Try this - it has worked for others, and might solve your issues as well:
Problem solved !!
Thanks to Ortur Support who did really great.
My problem was due to my grounding, which was not properly done. Static electricity bursts from the X belt’s movements was causing the disconnections/error:8.
We attached a copper wire on one of the 4 screws of the laser module’s top plate.
Wire then connects to a X-axis’ gantry screw. From that screw, another wire goes and connects to the Y-axis’ gantry screw.
Wires go through cable looms to keep everything neat.
Since then, …
system
(system)
Closed
March 9, 2021, 4:27am
#3
