[MSG:Warning: Flame Sensor Disabled by User OverRide]
[MSG:Flame detector Inactive. Luminosity too high]
Grbl 1.1f [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok pourquoi cela ne fonctionne pas et comment l’activer 'il vous plait
Not sure why it’s not working, but I’ve included one post from this forum and another from the web.
Disabling or enabling the flame detector on an Ortur Laser Master 2
The flame detector on your Ortur Laser Master 2 can be enabled or disabled using the GRBL setting $261.
To disable the flame detector
- Open the console in your laser control software (e.g., LightBurn or LaserGRBL).
- Type
$261=0in the console and press Enter.
This will disable the flame detector and prevent it from triggering the alarm during operation.
To enable the flame detector
To turn the flame sensor back on, you can enter $261=70 in the console. According to Ortur, the value represents the sensitivity level, so setting $261=70 enables the sensor at a specific sensitivity. Some older information may suggest using $261=1 , but the updated information indicates that $261=70 is the recommended setting for enabling the flame sensor.
HTH
